Help! Vacuum line mess
Old Feb 5, 2014 | 07:03 AM
TennesseeBoy's Avatar
TennesseeBoy is on a distinguished road
Had the same problem, the three way switch on the Xfer case was hooked up wrong making the engine suck vacuum through the vent hose. If you want some detailed pics I can upload them.
Old Feb 5, 2014 | 09:20 AM
Vacuum lines should be (4WD CPI):
back of manifold---short pc of hose---"Y" connector (extra fitting is purge canister vac line)---short pc of hose---check valve with four outlets (1. vac ball, 2. heater ctrls, 3. cruise ctrl, 4. xfer case 3 way valve)
make sure there is a hose coming from the top of the purge canister is connected to the front of the intake.
Old Feb 7, 2014 | 09:46 PM
Skitzoape's Avatar
Skitzoape is on a distinguished road
if you could get me pics that would help out alot man and i think thats whats missing, the piece from the intake into a Y. my check valve only has 3? the front line is connected.
ill look further into the rest as soon as it gets back from the shop, i had a terrible noise coming from the front of the engine, the tensioner pulley's bad and apparently when they did just their basic diagnostic it was running way too cool. so waiting to get it back monday.
Old Feb 12, 2014 | 01:10 PM
Skitzoape's Avatar
Do you know what is suppose to plug into thr rubber booted plastic line? I got everything connected but that
Old Feb 13, 2014 | 07:42 AM
Smitty Smithsonite's Avatar
Depends on where it is - could be to the vacuum orb ... or direct to the throttle body .. or into that check valve ...
Old Feb 15, 2014 | 08:35 AM
Skitzoape's Avatar
its comes up from behind the engine, its the line in the third pic of the ones i uploaded.
Old Feb 22, 2014 | 03:44 PM
Skitzoape's Avatar
Update: i replaced/re-ran some lines and replaced the check valve with a new one of the one thats in the pics. but i have no vents, any suggestions? is there a different kind of check valve? someone said something about a 4-port valve but i could only find one like the one in my pics
Old Feb 23, 2014 | 06:44 AM
http://www.amazon.com/gp/aw/d/B000C9C82W/ref=redir_mdp_mobile
here is the 4 way chk valve on Amazon.
Old Apr 5, 2014 | 08:05 AM
NCSurvival's Avatar
NCSurvival is on a distinguished road
Throttle body idle set screw is preset. DO NOT ADJUST! You're begging for problems if you do.
Old Apr 8, 2014 | 11:34 AM
Skitzoape's Avatar
I dont have a tbi, mine is cpi
intoodeep95
17
Nov 9, 2012 08:53 AM
87samurai
Oct 9, 2010 03:20 AM
Blazer_boy
Nov 23, 2009 03:26 PM
Red03
Suspension Tech
Sep 20, 2008 09:25 AM
strongboy2005
Feb 18, 2006 11:07 PM
