How many O2 sensors do I have?
Old Feb 10, 2009 | 04:57 PM
s10machine's Avatar
s10machine is an unknown quantity at this point
Default How many O2 sensors do I have?
Working on my 91 s10 Blazer, 4.3 4x4. Looking at Advance Auto's web site, they say I have two, an upstream and downstream.Downstream waseasy to get, down on the Y pipe. I assumed I could see the upstream sensor, in the manifold. When I went to remove it, I realized I had the wrong one, I think it is the coolant temp sensor over there, on the passengerside.
Sonow I'm not sure there is a secondo2 sensor, Haynes and Chilton only mention the one. So if there is only one, which should I put in there, upstream or downstream? I assume downstream, because it plug fits. But we can all see how fas assuming anything has got me. I appreciate any help you guys have to offer.
Thanks for checking me out.
Old Feb 10, 2009 | 06:22 PM
rdhack's Avatar
rdhack is an unknown quantity at this point
Default RE: How many O2 sensors do I have?
Mine only has one. Crawl under it and look. There will be one for sure just before the cat converter on the right side just behind the right front wheel. It is a single wire. Run your hand along the rest of the exhaust pipe (when cold) all the way to the muffler. I bet you do not find one.
Old Feb 10, 2009 | 06:52 PM
s10machine's Avatar
Of course I found that one, it is the one I referred to as 'downstream'. I am trying to determine if there is another o2 sensor on a 4.3 from 91. Thanks tho
Old Feb 10, 2009 | 06:59 PM
rdhack's Avatar
Downstream means AFTER the cat converter. The only one you probably have and found is upstream.
Old Feb 10, 2009 | 09:59 PM
Yep, the sensor you have found which is directly after the "Y" in the y-pipe and before the catalytic converter is the upstream sensor. If you do not have one behind the catalytic converter, then you only have one sensor.
Old Feb 10, 2009 | 10:25 PM
s10machine's Avatar
Okay, that is great, I only have one o2 sensor to worry about. Thanks swartlkk
melstal
Mar 31, 2015 05:08 PM
scphill34
Mar 31, 2013 09:41 PM
jeff771
Apr 12, 2012 11:37 AM
Supercity
Jul 10, 2011 01:23 PM
cjbehrens
Feb 28, 2009 11:14 PM
