How to replace TBI?
Old Feb 18, 2007 | 05:31 AM
keithscianna's Avatar
keithscianna is an unknown quantity at this point
Default How to replace TBI?
One of the injectors is not working on my 91 4.3. I am Going to have to get a new (used) TBI from a junkyard. How can i relive the fuel pressure so i dont get gas everywhere? And will i just be able to unbolt it and bolt the new one on without making adjustments?
thanks,
keith
Old Feb 18, 2007 | 12:20 PM
Default RE: How to replace TBI?
Your TBI isn't running huge amounts of pressure like the CPI & MPI engines. But you should be able to pull either the fuel pump relay or fuel pump fuse and try to start the truck. This should quickly relieve the pressure in the lines. Even without pressure, there will be some fuel that will spill out. You will want to have some rags under the line(s) to catch this.
Good luck!
Old Feb 18, 2007 | 08:03 PM
thanks
deathman
Aug 14, 2011 11:25 PM
maverik78
Performance & Brainstorming
Apr 11, 2010 10:05 PM
matthp
Nov 17, 2009 11:02 PM
SniperX13
Suspension Tech
Jun 20, 2006 01:06 AM
Jumbo222
Engine & Internal
Aug 31, 2005 01:32 AM
