How to shorten the hood release cable?
Old Apr 21, 2007 | 05:05 PM
tmitbyh's Avatar
tmitbyh is an unknown quantity at this point
Default How to shorten the hood release cable?
The hood release cable on my '94 S-10 Blazer is too long and doe snot pop the hood properly. How do I go about shortening this cable so that it is the proper length?
Old May 10, 2007 | 02:42 PM
dannydarko's Avatar
dannydarko is an unknown quantity at this point
Default RE: How to shorten the hood release cable?
Can you get the hood open at all? If not a good way to get in there is to actually go under your car and take off the entire upper half of the latch system from your hood. There is a straight shot to the two bolts as long as you have socket extensions. From there you may just need to replace your cable with a new one. I picked one up from a junkyard for about 15 bucks.
Old May 28, 2009 | 12:50 PM
jdt's Avatar
jdt
jdt is on a distinguished road
if you can get the hood open.i put a split shot on my cable.you need 2 needle nose pliers,one to pull the cable tight and one to crimp the splitshot to the cableto take up the slack,also strech the hood spring a little.
Old May 28, 2009 | 01:08 PM
Yep. That's what I would do.
Old Oct 12, 2009 | 09:54 PM
boscoedoodle's Avatar
boscoedoodle is on a distinguished road
the easiest fix is saw a slot in the side of a small nut, pull some slack in the cable and slip the nut over the cable and squeeze it shut, making the cable stroke shorter
Old Oct 13, 2009 | 08:01 AM
abig84's Avatar
ha thats a great idea... i myself used a ziptie
sprbld417
Apr 25, 2011 07:28 PM
4x4blaze
Mar 9, 2011 07:20 AM
DAVE SR
Nov 7, 2010 03:10 PM
blazer4x4
Sep 12, 2007 11:59 AM
Hanr3
Jan 22, 2007 02:30 AM
