?? How to siphon gas from 1992 S-10
Old Dec 15, 2007 | 09:13 PM
ptcoins's Avatar
ptcoins is an unknown quantity at this point
Default ?? How to siphon gas from 1992 S-10
Is there a way to siphon the gas out to empty the gas tank so the tank can be removed more easily?
The tank is about 1/4 full. I'm removing the tank so I can replace fuel pump.
It is a 1992 S-10 4.3L vortec.
I tried to get a siphon tube in the gas tank fill tube, but it wouldn't go. I pulled off the fuel filter and shoved the siphon tube up there and that wouldn't do anything either.
Old Dec 15, 2007 | 09:18 PM
Brandon31386's Avatar
Brandon31386 is an unknown quantity at this point
Default RE: ?? How to siphon gas from 1992 S-10
if its only a 1/4, i think you can muscle that. I havea FULL tank i have to drop in the next couple days. lol. I was planning on siphoning the gas, but it looks like your having trouble. Probably cuz it is so low, maybe youre just sucking air? idk. Did you check your relay to make sure that is not bad?
Old Dec 16, 2007 | 12:28 AM
Hanr3's Avatar
gas weighs roughly 8 pounds per gallon.
If you rtank is 18 gallons and 1/4 full (rounded to 5 gallons) is 40 pounds plus the weight of hte tank. If that too much for you, use a jack, board, and a friend.
Old Dec 22, 2007 | 02:08 PM
You should be able to pull off the fill hose and siphon from there.
Or you could just remove the fuel filter and allow the pump to drain the tank. But then again, you are probably replacing the pump, but from your other thread, you haven't even tested the pump yet so I really fail to see why you are replacing it without first properly diagnosing it. Throwing parts at a vehicle is a sure fire way to waste money.
Old Dec 23, 2007 | 03:02 PM
but sometimes throwing parts at a vehicle is a way to fix it.
you need a pretty long hose to get the gas out. I just did it the other night.
Tch1988
Mar 12, 2013 08:29 PM
Murder after Midnight
May 19, 2011 06:54 AM
trapperjohn4077
Jun 7, 2010 10:49 AM
degaine_designs
Aug 19, 2009 11:12 PM
SnowRemorse
Jan 4, 2008 11:26 AM
