hub bearing
Old Oct 24, 2009 | 11:38 AM
green75's Avatar
green75 is an unknown quantity at this point
Default hub bearing
i replaced the drivers side hub bearing 2 days ago
i notice a grinding noise
today i took it all aprt looks like the cv joint isnt in all the way like a1/4 inch.
i tightend the 3 bolts holding the assembly on and that is when the isnt touching in the back.
i tightend the big nut and it doesnt pull it in. any help would be nice thank you
if my ball joint is bad would that be a problem too
Old Oct 24, 2009 | 11:40 AM
Sounds like there is a fitment issue between the two... Did you compare the hubs to each other?
Old Oct 24, 2009 | 11:41 AM
green75's Avatar
looks good matches up
bigrackhunter50
Apr 11, 2007 01:08 AM
KLBlazer07
13
Jan 14, 2007 04:16 PM
Marcin
Nov 9, 2006 11:31 AM
Chavez96
Sep 20, 2006 04:04 PM
greengoose89
Aug 3, 2006 07:32 AM
