Idle issue, delayed downshifts
Old May 26, 2013 | 11:06 AM
jfrust64's Avatar
jfrust64 is on a distinguished road
Default Idle issue, delayed downshifts
Happy Memorial Day all and thank you vets!
I have a 94 S-10 W code and it has started to idle higher than normal and will cruise at 40 mph without touching the gas. The tranny won't kick down to low until the truck is almost stopped. Once the rpms drop the SES light comes on until you hit the gas again.
I replaced the cap, rotor, plugs and wires along with an oil change but I'm thinking the TPS or IAC but was looking for some advice before I hit the parts store.
Thanks in advance for any help/direction
Old May 31, 2013 | 08:14 PM
go-part's Avatar
Former Sponsor
go-part is on a distinguished road
Old Aug 6, 2013 | 07:55 PM
jfrust64's Avatar
So we replaced the throttle position sensor, the idle air sensor and the ECM and no change. We just had it out and the exhaust manifolds on both cylinder banks are glowing red. I don't think it should be running this hot. Could a bad cat create the excessive heat and the idle issue?
Any advice would be appreciated
Old Aug 6, 2013 | 08:14 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
A bad cat can cause those symptoms, yes. If you have the ability to take the temperature of the cat, let the engine idle for a while then see if the cat has a significant temperature change from the front half to the back half.
Old Aug 7, 2013 | 09:37 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
vacuum leak, running too lean. Also check ign timing. Make sure throttle isn't hanging open
tallhorseman
May 3, 2012 05:45 PM
91blazerlifted
Mar 6, 2012 04:09 PM
old 5k0ol
Jun 11, 2011 10:45 AM
dimone545
Sep 21, 2010 12:08 PM
fuzzball447
Jul 29, 2007 05:25 AM
