idles high, shifts hard
Old Mar 20, 2011 | 01:53 AM
dmc919's Avatar
dmc919 is an unknown quantity at this point
Default idles high, shifts hard
the other day my blazer started idling really high can be going 30mph and let go of gas stays a constant 30, and shifts really hard and late in every gear, have to give it alot of gas for it to shift. I have checked the idle air control valve and its moving back and forth when i turn the key on, also took egr valve off, its clean no carbon. no check engine light either, i'm lost anyone got an idea?
Old Mar 22, 2011 | 10:57 PM
dmc919's Avatar
is there a sensor that would effect the transmission and idle speed?
Old Mar 23, 2011 | 10:00 AM
Not really related, but a vacuum leak could possibly skew the MAP readings which may cause a firmer shift.
You need to check over all of the intake gasket surfaces & vacuum lines for signs of a vacuum leak and correct any leaks that you find. Clean the throttle body and make sure that the throttle isn't getting stuck open.
bdk
Dec 23, 2011 10:33 AM
TheNasty0ne
Dec 17, 2010 09:59 PM
Dfretty
Sep 9, 2010 09:54 PM
hubert hefner
May 12, 2010 05:55 PM
bearsfangb1
Mar 24, 2010 07:04 AM
