ign switch will not turn off an cant get in park
Old Oct 28, 2011 | 09:01 PM
moon's Avatar
moon is on a distinguished road
Default ign switch will not turn off an cant get in park
need help bad , my switch will not turn off an cant shift back to park. only can go to start side of switch does not release all way back very hard what is wrong, i took off trans linkage an trans shifts not no problem here, is there any thing electric that controls this this is a 93 blazer with tilt colum
Old Oct 28, 2011 | 10:25 PM
Start with the shifter. It has to go back to park before you can get the key out. You should still be able to shut off the engine.
Old Oct 30, 2011 | 12:44 AM
moon's Avatar
Thumbs up
thanks for the help, i had to take out the switch before my colum would go back to park the tumblers in the switch was froze up would not rotate
first time i ever saw one do like this only rotated half turn back. even with the switch out still was not rotating.
Old Nov 28, 2011 | 07:53 AM
midnightrider's Avatar
midnightrider is on a distinguished road
Ahhhhh, the old Column problem....had the same, couldn't turn off the truck because my column shifter wouldn't go back far enough on the column for the ignition cyclinder to rotate back, now I have to keep my eye on it when I'm getting ready to leave the truck, PITA !!!!!
J
natem504
Apr 22, 2015 04:07 PM
Boiler_81
Oct 30, 2011 05:01 PM
505loco505
Jun 1, 2011 05:11 PM
jimmy79
Jan 2, 2009 08:38 PM
fortmyerspolice
Feb 19, 2006 10:56 AM
