I'm only getting 14 mpg?!
Old 03-31-2010, 05:26 PM
warthogdriver's Avatar
sounds like my ride...i avg 14.5 mpg...now that i upgraded the overhead console...i am depressed reading that.
i do get 22 on highway...just alot of crappy city driving.
Old 03-31-2010, 07:25 PM
Blazers.B.Kewl's Avatar
Blazers.B.Kewl is an unknown quantity at this point
Originally Posted by musclecar70sfan
No problem... I make the same mistakes all the time lol. Thanks for the advice! Regarding the thermostat, my temp gauge (on the dash) usually hangs around in the 170-185 range. Is that OK?
I think that's good. Mine usually hangs around there. just over halfway up to the 200 mark right? That's about where it should be.
Old 03-31-2010, 08:29 PM
musclecar70sfan's Avatar
musclecar70sfan is on a distinguished road
Yeah just about. At least that's ruled out.
Old 04-08-2010, 12:03 PM
hayeri1's Avatar
hayeri1 is on a distinguished road
Cool
You've mentioned you have run the truck low enough on fuel to cause a stumble when stopping. The flat GM fuel tanks are poorly baffled, so a lot of sloshing occurs in the tank. Even with fuel starvation when stopping, there could be a gallon or more of fuel sloshing around in the tank, but it isn't staying near the fuel pump pickup.
Some GM vehicles are so bad, the fuel gauge will move up or down when accelerating or stopping.
Also, when my Blazer is sitting on empty ('94 w/20 gal. tank), it generally takes about 17 gal. to fill it (topped off). The sending unit is incapable of showing the last couple of gallons in the tank, especially when you have a wide, flat tank.
Old 04-08-2010, 12:13 PM
DSMayo's Avatar
DSMayo is on a distinguished road
My 2002 is like that as well where it will show empty but only 16-17 gallons will fill her back up. Is it safe to say that if the sending unit cannot read the last couple gallons, the fuel pump will not be able to use that fuel either?
sorry if Im thread jacking
Old 04-08-2010, 04:35 PM
That's what I thought. And yes my fuel gauge is pretty bad lol. It does jump up and down on stops and heavy acceleration.
Old 04-08-2010, 04:39 PM
99blaz's Avatar
99blaz is on a distinguished road
I average like 15.7 or something and about 70% of my driving is highway so your not getting to bad.
Old 04-08-2010, 11:36 PM
hayeri1's Avatar
Cool
The fuel pump can siphon much more gas than the sending unit can read, but it never removes all the gas from the tank. The sending unit float bottoms on the tank before the tank runs dry.
I don't normally let my Blazer get below 1/4 tank, because the fuel pumps get hot when they are not submerged.
Old 04-10-2010, 08:17 PM
tjspillman's Avatar
tjspillman is on a distinguished road
Do you know you gear ratio? my wifes 94 and my 96 both have 3:42 gears and we both get about 15-17 mpg. and both are 4x4's. these numbers are pretty close to our window stickers fuel rateing. you could be one of the few that has the 3:73 gears. just a thought.
Old 04-10-2010, 08:29 PM
truesmack's Avatar
truesmack is an unknown quantity at this point
Yeah, it seems like 3:73 gears hurt your mpg for sure, not sure if I really like the feel either, newer different blazer thou.
Quick Reply: I'm only getting 14 mpg?!
