Install and level torsion bars and keys process?
Old Oct 1, 2018 | 08:40 PM
kallen90's Avatar
kallen90 is on a distinguished road
Default Install and level torsion bars and keys process?
I'm in the process of rebuilding the front end on my 94 blazer. I have the torsion bars out and the new control arms installed.
What is the process for installing the keys on the torsion bars?
I did the opposite of how I installed them and was just going to measure the shank on the bolt that sticks in the wedge part to get them as close to even as possible.
I lifted the lower control arm up as high as I could (I slid a floor jack under it when I removed the torsion key) slid it over the hex part of the bar, installed bolts in the control arm bushings, slid the torsion bar into they key. I then put the clamp on the key, installed the bar in the slot and tightened the bolt as close to where it was originally.
Is this the right way, if not what am I doing wrong?
Old Oct 2, 2018 | 04:30 AM
There are measured heights that are used to set the height. The tension on torsion bars are adjusted using the bolts to set the height to the specifications. I've attached an excerpt from my 1999 GM manual that describes how to set the height.
File Type: pdf
Old Oct 2, 2018 | 08:32 AM
kallen90's Avatar
Thanks for that, that was a big help.
Now when putting the torsion bars back into the keys and lower control arm, where do the control arms sit? Do I leave them all full drop, do I bounce the car, then lift it, then throw the bars into the keys?
Old Oct 2, 2018 | 11:37 AM
Glad it was a help. Regarding installing the torsion bars, I've never done that. Maybe someone else knows? If I find some information, I'll post it.
Toby Hanson
Sep 11, 2020 12:44 PM
ckroll98
Lifting Tech
Oct 17, 2013 09:55 AM
Jimmy_Blazer
Feb 22, 2012 10:50 AM
Blazin_Jason
Suspension Tech
Apr 15, 2007 07:43 PM
nai0013
Apr 14, 2007 09:58 PM
