Just got a 89 S10 Blazer 4.3 and it Randomly goes nuts! Crazy Oil Pressure and Stall
I just got this yesterday. This is mt first Chevy anything so i am a novice to this car. One minute the truck drives great, just like its supposed to. Then the next the idle turns to hell, Oil pressure gauge goes nuts, trucks starts to lose power and struggles to stay started, lights dims. It will do this for a bit, sometimes longer than other times. Then it will be normal again, perfect idle, driving smooth. All of this is random, happens at random times for random intervals. Any ideas?
Ive had it only 2 days so ive tried to limit my driving. Ive had it happen a few times after starting, while idle. Another time right as i was taking off, it was surging and and once up to speed worked fine. Another time as i was pulling into the gas station. 70% of the time it drives like its supposed too.
Also, there are 2 little nozzles at the top that squirt fuel down, one of the connectors on one of them is half melted it looks like. I cant find a replacement connector online, just keep getting injectors
http://www.s10forum.com/classifieds/...ct/58364/cat/6 Look like this? this is not a carb. It's a throttle body. Early form of fuel injection. Are both the injectors spraying fuel? They should spray in pulses and there SHOULDN'T be a solid stream of fuel down the center.
Fuel Injector Wiring Connector | 1994 Chevrolet S10 Blazer 2WD 6 Cylinders Z 4.3L TBI | AutoZone.com here is a connector from autozone. That looks bad but the important part is the contacts and to make sure they are spraying correctly.
SubbinBlazer
May 24, 2013 12:56 PM
chris015
Feb 20, 2013 02:30 PM
cardsNblazer
Aug 11, 2008 08:26 AM
