leak
Old Dec 8, 2006 | 10:34 AM
FImports's Avatar
FImports is an unknown quantity at this point
Default leak
http://i141.photobucket.com/albums/r...7/HOUSE011.jpg[IMG][/IMG] 92 s-10 blazer 4.3 its on the passenger side anyone know what this is.
Old Dec 8, 2006 | 11:07 AM
rooster's Avatar
rooster is an unknown quantity at this point
Default RE: leak
isn't that ur stater motor! the leak might be above it from maybe the back of the valve cover where they are notorious to leak and is hard to see.
Old Dec 8, 2006 | 11:10 AM
FImports's Avatar
Default RE: leak
IS IT A BIG JOB TO FIX
Old Dec 20, 2006 | 09:18 PM
Default RE: leak
Your other threads on the subject of oil leaks...
vaule covers, oil cooler line, rear main seal, no oil
All of these threads are off-shoots of the 'leak' thread.
Old Dec 20, 2006 | 10:08 PM
FImports's Avatar
Default RE: leak
and not one is properly answered yet!
Old Dec 21, 2006 | 02:38 AM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
Default RE: leak
Talk about SHORT
Sheesh, what you expect it to be like take to the shop they look at it and tell you in less then 10 min?
Man I hope you are not like this with IMPORTS. Most of the IMPORT forums would ban you for acting like this or just IGNORE you.
For one:
RELAX you only live once and being stressed out like that only SHORTENS you life span
For two:
The pictures help to trouble shoot that was a good move on your part
For three:
Not all of us live on the computer and these forums. We do have jobs and life outside of here. Give it some time an you will get answers. If you keep pushing like this no one will ever respond. They will leave you to guessing or take to shop.
For four:
It does look like a leak down from above the starter.
So I would be checking these:
Valve covers (not hard to change out due to 3 top mounted bolts that hold it down)
Remote Oil Filter (check to ensure that the seal on that is good)
Distributor seal (this one is kind of hard to get at, but if you take a rag/towl and dab it behind the engine under the distrib you can see if you have fresh oil there. If so then you need to pull your distrib and replace the rubber O-ring that seals that)
Try these and hopefully you can relax some. Keep posting a pic and it can help in getting a reply that will be more direct to the issue. And remember you only live once, try to enjoy life not stress it.
Old Dec 21, 2006 | 07:31 PM
FImports's Avatar
Default RE: leak
thanks a lot.your righti've been a real (a--hole)lately to all of you sorry guys and girls.from now on i will limit my post and stop posting threads of the same topic.......sorry everyone andmerry christmas to all,have a good one.oh and just so you all know everyone has been such a great help with all your advice
Old Dec 21, 2006 | 10:01 PM
MNHawk's Avatar
Default RE: leak
If you do a search for Valve cover you will find some helpful threads on removing and replacing the gaskets if this turns out to be your issue. Most of us are more then willing to input our exp. from working on these Trucks (or other vehicals in the past). Just need to give it some time over mass posting
Happy Hollidays to you also and to all who are upon this Forum
ComputerNerdBD
Aug 9, 2011 08:04 AM
BubbaBrooks
May 18, 2011 08:38 PM
abadinalbany
Jun 1, 2009 08:27 PM
TAZ454
Jan 28, 2008 10:11 AM
