low oil pressure after engine warm
Old Jul 21, 2013 | 09:16 AM
Alberto Daher's Avatar
Alberto Daher is on a distinguished road
Default low oil pressure after engine warm
Hi, I own a 1989 chevrolet s10 tahoe blazer 4wd. My oil pressure gage reports a low lever oil pressure after the engine is warm. What could cause this ?
Old Jul 21, 2013 | 09:22 AM
chris015's Avatar
How low? say 1/8th inch above the red line? If so thats normal. these engines only need 6-8 psi at ever 1k rpm.
Old Jul 21, 2013 | 09:24 AM
Hi chris015, it goes down to 0 (zero)
Old Jul 21, 2013 | 09:37 AM
chris015's Avatar
oh. ouch.Do you have the 4.3 or 2.8?
First thing to do is,check oil (duh,but u would be surprised on who doesnt)
Get a mechanical gauge. Replace the oil sending sensor with it and see what the real pressure is. Sometimes the gauge or sensor can go bad resulting in this. If pressure is still 0,its time to replace the engine. You could try the oil pump,but chances are the engines just tired.
Old Jul 21, 2013 | 10:19 AM
I have the 2.8, from April 1995, nice truck !! I noted that sometimes, when the spark plugs or the spark plugs wires are bad, the oil pressure goes down after engine warm, given to a poor electricity condition inside the engine. But now I checked with a multimeter the spark plugs and wires and are ok.
Old Jul 21, 2013 | 11:14 AM
cleburne red's Avatar
I don't think the ignition system would have anything to do with your oil pressure. If the oil pump is good, then the low pressure is a result of excessive clearances, i.e. worn out bearings. A new oil pump, or even thicker oil might help the problem. Assuming the sending unit or gauge is working properly.
Old Jul 21, 2013 | 01:30 PM
chris015's Avatar
he is correct. the electrical (spark) has nothing to do with the sending unit as long as your alternator and battery is good.
sounds like you need a new engine. Test pressure using a mechanical gauge first.
Old Jul 21, 2013 | 04:01 PM
Ok, I will check it with a mechanical gauge.
Thanks
blazer485
Nov 24, 2013 09:42 AM
projackedreality
Nov 18, 2013 06:12 PM
Brian26
Sep 19, 2012 04:24 PM
rohde782
Oct 8, 2009 08:36 PM
Inferno
Oct 22, 2006 08:56 PM
