Main Bearings
Old May 14, 2008 | 07:35 PM
apbtdlk's Avatar
apbtdlk is an unknown quantity at this point
Default Main Bearings
Hello all, I just bought a 1994 Chevy Blazer 4 door, automatic with the 4.3 liter (vortex) for $400.00 and this is my first chevy vehicle. But the problem is I think the main bearing is bad in it. So my question is- Do I have to take the front axle out to replace them through the oil pan? Thank you for your time
Old May 14, 2008 | 07:45 PM
972DRBLAZER's Avatar
972DRBLAZER is an unknown quantity at this point
Default RE: Main Bearings
welcome to forum. try running a search, and you should find all the info you need.
Old May 14, 2008 | 08:22 PM
cliro's Avatar
cliro is an unknown quantity at this point
welcome to the forum. you'd probably get more answers posting in the appropriate section.. this section for introductions.
Old May 14, 2008 | 10:52 PM
blazin97's Avatar
blazin97 is on a distinguished road
easiest way is to pull the motor.
Old May 15, 2008 | 01:27 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
Are you talking about a crank bearing in the engine when you say main? If so you have to pull the motor and do a tear down and rebuild.
Old May 15, 2008 | 01:43 AM
*Moving to 1st Gen Tech*
If you have to replace a main bearing, you have to pull the motor. This cannot be done from under the truck.
Old May 26, 2008 | 11:43 AM
The Slacker's Avatar
The Slacker is an unknown quantity at this point
It would be easier and less frustrating to do it with the engine totally removed. Cranks are big and would require a lot of room. I don't know if it's even possible without removal of an insane amount of components.
chevygonzalez
Oct 31, 2010 08:11 PM
caverwv
May 18, 2010 11:30 AM
bigdaddykane93
Aug 3, 2009 03:03 PM
FImports
Dec 13, 2006 03:00 PM
smitty
Aug 12, 2005 11:38 PM
