Name this vacuum/vent hose...
Old Oct 27, 2013 | 09:11 PM
TennesseeBoy's Avatar
TennesseeBoy is on a distinguished road
Default Name this vacuum/vent hose...
what is this hose and should it have vacuum on it? it does if I hold my thumb on it at warm idle.
Attached Thumbnails Name this vacuum/vent hose...-image.jpg
Old Oct 27, 2013 | 09:25 PM
chris015's Avatar
do you still have your vacuum ball on the passenger side? if its not plugged up,thats your hose which has been cut.ive got a 93 vin w. tryin to remember whats all on that side.
Old Oct 27, 2013 | 09:48 PM
Yep its there, but it already has a hose hooked to it just like this one. I was thinking this may be the front diff vent, but the vacuum it was drawing threw me off.
Old Oct 27, 2013 | 09:50 PM
chris015's Avatar
its definitely not the diff vent. Look behind your engine,passenger side of the distributor. you'll see a T,and a bunch of lines etc that plugs into your manifold. any capped off or missing?
Old Oct 27, 2013 | 10:03 PM
There is a tee off the back of the manifold. It has four small hoses coming off of it. None plugged or missing, haven't traced them all out yet, got stuck on this one.This all started looking for the cause of rough idle of course.
Old Oct 27, 2013 | 10:18 PM
chris015's Avatar
the leak can cause the bad idle...For now id just stuff a screw in it.
Old Oct 27, 2013 | 10:27 PM
I'll try to chase it out and see where it ends. when I put my thumb over it it draws a really slow vacuum, unlike the brake booster hose that can give you a pretty bad red spot. I've searched diagrams till I'm cross eyed and had no luck identifying it yet.
Is there anything else on the passenger side it could go to?
Old Oct 28, 2013 | 08:18 AM
chris015's Avatar
i dont think so unless you have 4wd.
I'll take a look at my 93 today and see where everythings routed.
Old Oct 28, 2013 | 09:26 AM
It's a 4WD. I'll update my sig.
Old Oct 28, 2013 | 10:36 AM
chris015's Avatar
do you have a vacuum line running to your 4wd actuator under the battery tray?
