need help on transfer case oils
im looking for a better transfer case oil for my 93 s10 blazer. Specs call for dex II or IIE atf. i was wondering if i could use Lucas High Perf. 80W-90 since it says great for transfer cases. I know 80W-90 is thicker but would it work since this is my first 4x4 build. I want more protection without much sacrifice of parts.
DO NOT put gear oil in your transfer case. Run Dexron III or the new Dexron VI, but not gear oil.
Have you ever wasted a transfer case using the recommended fluid? What is prompting your quest for a "better" lube?
nothing. i just got my rig but i want something good. the guy at autozone had a half *** answer for me and i wasnt satisfied. i want something good but only know haynes knowledge about transfer cases. whats the best brand.
if you're worried about having better protection, step up to a full synthetic ATF for your case.
and if you're worried about protecting that t-case, then you might as well do both diff's too.
as for "Best Brand"............well, that's all a matter of opinion.
Flyfishen
06-18-2019 11:22 AM
jumpinjimmy
04-03-2014 09:48 PM
bensaintonge
12-03-2013 08:14 AM
MrRox
03-23-2009 11:27 AM
95_4door
03-21-2008 07:22 PM
