need your help....dripping injectors
All of a suddenthe 2 injectors on my '86 Blazer 2.8 started dripping. There is a nice conical spray when you rev it up but I can see almost a stream dropping down from the center of the injectors. At idle there is very little spray and mostly drips. If I energize the fuel pump test connector with the return line pinched off there is no leakage from the injectors or anywhere else, dead head pressure is 18 psi. New fuel pump, new inline filter, new o rings, gaskets and injector filters, new pressure regulator diaphram, pressure test is within specs, no visible leakage anywhere, no restriction in return line and it has thrown no codes. It's hard to believe that both injectors would malfunction at the same time so I'm a little hesitant to spend the money on 2 new ones until i've exhausted all other possibilities. Thanks in advance for any and all help given...my back is killing me from bending over this thing...lol
RE: need your help....dripping injectors
something is failing to hold back from what it sounds like i would put my money on having to replace them unless someone knows of something better to do.
William Flynn
09-28-2011 05:20 PM
contour1
01-03-2011 04:36 AM
BlazinJay84
12-06-2007 08:00 PM
Matty Kling
10-10-2007 01:25 PM
junkmonkey
09-18-2007 06:37 PM
