new hub question
Old Aug 28, 2013 | 08:02 PM
rtasd3's Avatar
rtasd3 is on a distinguished road
Default new hub question
1993 full size blazer4x4---in the process of a full front end rebuild....doin everything. I do have 2 questions I could use a hand with. pitman arm removal. manual says a puller but it dosent look like near enough room to get a puller in there. how do I get it off #2 I ordered all moog parts including hubs..got passenger side axle and hub together and torqued. Should it be pretty stiff to turn?? I would assume that it is stiff due to being new and need to break in. Hubs were stiff outta box to turn by hand....any thoughts. Thanks in advance
Old Aug 28, 2013 | 08:53 PM
chris015's Avatar
stiff is ok,drive it 50 miles and feel it,itll loosen up. For the pitman,if its like the s10/s10 blazer you have to remove the gear box bolts and turn it a little sideways to get a puller on it.
Old Aug 29, 2013 | 09:05 PM
ohsofly's Avatar
Stiff new hubs is a good things. And 2x on the bolt removal to get the steering box access better.
daveg999
May 8, 2012 04:10 PM
abadinalbany
Aug 1, 2009 12:47 PM
1989blazed
Mar 25, 2008 09:34 PM
yazan84
Mar 10, 2008 06:53 PM
yazan84
Nov 13, 2007 12:38 AM
