no spark at spark plugs
I have a 1992 s10 blazer with 4.3L tbi 4x4. last week the oil pressure sender went out i replaced it started it up drove about 10miles made it home no problem. then it just died when i pulled into my driveway ever since then i haven't had any spark to my plugs. replaced ignition coil, new distributor, new wires, new plugs. turns over good fuel pressure need some advice. what could be causing this.
Running with the battery just means the alternator is putting out, which is good. but you also run the risk of fryin the ecm....as for the fuse location...check either tucked up in the driver fender or on the passenger side firewall...
good luck
good luck
Thanks ill check it out when I get home
JavierEscalonJr
10-14-2020 11:38 PM
abe_f
04-01-2013 11:19 PM
Yankee Team1020
23
08-03-2011 08:05 AM
