Oil Filter leak - is there a separate gasket?
Old Mar 18, 2008 | 06:47 AM
Dog's Avatar
Dog
Dog is an unknown quantity at this point
Default Oil Filter leak - is there a separate gasket?
I just did an oil change and was hoping to resolve an oil leak that appeared to be caused by the oil filter not being screwed on correctly. It now continues to leak, from what appears to be from the base of the new oil filter.
Question is: is there a gasket or O-ring on the block that the oil filter contacts that could be bad? I didn't bother to look when I did the oil change, and would rather not go back in unless that could definitely be the problem. If not a gasket, any other ideas? It's not the valve covers, and it certailnly appears to be isolated around the filter. Thanks in advance...
Old Mar 18, 2008 | 07:01 AM
thegr81's Avatar
Default RE: Oil Filter leak - is there a separate gasket?
What it sounds like is that the old gasket from the old filter stuck to the block and you put the new one on over it creating the leaky situation you have!! What your going to have to do is remove the filter over a bucket or something to catch the oil and check the block and filter for an extra gasket if there isn't a extra gasket present inspect the top of the filter for bends in the gasket ring seat and see were it could be coming out at!!
Old Mar 18, 2008 | 07:06 AM
As Ryan said, if the old gasket stuck to the block, it is quite possibly the cause of your troubles.
If you cross threaded the filter fitting in the block, this is removable and thereby replaceable. I am not sure where you would go to get one other than the junk yard, but I wouldn't be surprised if there was something like this at your local autoparts stores and/or dealer.
Old Mar 18, 2008 | 07:17 AM
thegr81's Avatar
Kyle the part your talking about that screws into the block that the filter attatches too can be purchased at autozone, my buddies old s-10 had that issue and thats were we got a replacement from!!
Old Mar 18, 2008 | 07:24 AM
Good deal!
Old Mar 18, 2008 | 07:36 AM
Dog's Avatar
Dog
Cool - thanks for the quick responses guys! I'll check it out soon and report back...
Old Mar 18, 2008 | 07:40 AM
thegr81's Avatar
Not a problem, let us know what you find out!!
Old Mar 18, 2008 | 02:20 PM
Chevy Lover's Avatar
I also recommend applying a thin layer of oil to the oil filter gasket before installing it.
cleburne red
Jan 28, 2013 04:53 PM
ComputerNerdBD
Jan 23, 2012 06:04 PM
chris015
Apr 18, 2011 09:54 PM
TomSawyer
Jan 30, 2011 06:50 AM
JRDroid
Jan 21, 2011 08:24 PM
