ok...Whats the trick?
Old Sep 17, 2008 | 11:04 PM
jdazlin's Avatar
jdazlin is an unknown quantity at this point
Default ok...Whats the trick?
Which method is easiest for removing/replacing the motor mounts? Is it possible without taking out the engine? Whats the trick?
Old Sep 17, 2008 | 11:17 PM
WolfPack's Avatar
Default RE: ok...Whats the trick?
You gotta remove the motor mounts to get the engine out
Old Sep 18, 2008 | 08:04 PM
jdazlin's Avatar
The motor mount is a two piece thing. One is bolted to the motor the other is bolted to the frame. i only need to replace the piece bolted to the motor. There's a bolt that holds the two peices together, i have removed it but i cannot get the last bolt on the motor piece. i've already jacked the motor up as far as it will go with out taking it out, am i just going tohave to remove the engine for just one bolt?
Old Sep 18, 2008 | 08:07 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
have you tried a 3/4" breaker bar on it with an ext if needed?
Old Sep 18, 2008 | 08:11 PM
jdazlin's Avatar
No i have not, i will try and see what happens.
mitch_houser
Apr 2, 2012 06:28 AM
ldkronos
Dec 13, 2007 03:54 PM
topblazer
Tires and Wheels
Dec 6, 2007 07:03 PM
GMdesigner
Jun 22, 2007 11:43 AM
Blasir
Oct 7, 2006 03:42 PM
