parking lights & dimmer switch buzzing
Old Feb 23, 2010 | 08:49 AM
radiokid's Avatar
radiokid is on a distinguished road
Default parking lights & dimmer switch buzzing
I have a 1991 GMC Jimmy i noticed when i turn on the parking brake lights when the dimmer switch is at its fullest brightness the door buzzer starts buzzing. when i turn the dimmer down it stops buzzing.
I checked the fuses all the fuses are good, could be some sort of ground issue or is it a issue with the ignition switch. idk
Old Feb 23, 2010 | 12:13 PM
radiokid's Avatar
any one know where the buzzer is located under the dash?
I want to remove the buzzer, since its annoying and useless.
Old May 18, 2010 | 04:23 PM
Eff10's Avatar
Eff10 is on a distinguished road
I have the same exact problem! Just started today. Did you solve it yet? If anyone knows how to fix this I'd really like to know because it's really annoying. I know this thread is 3 months old but I just wanted to let you know someone else has the same problem and see if you have a solution.
Old May 18, 2010 | 07:26 PM
radiokid's Avatar
FIXED! i removed the buzzer from under the drivers side dash.
Just follow your ears and its located atop around the hood release cable handle.
It was a black box 3 in x 3in x1 and just pulls out toward the front of the vehicle.
streblo
Jan 24, 2012 11:50 PM
maepis
Dec 21, 2011 06:10 PM
84_K5
Dec 21, 2009 12:16 PM
blazerxtreme1
Jul 29, 2006 04:45 AM
blazerxtreme1
Jul 8, 2006 05:41 PM
