84- Dimmer Light Wire - where is it?
Old Dec 18, 2009 | 07:33 PM
84_K5's Avatar
84_K5 is on a distinguished road
Default 84- Dimmer Light Wire - where is it?
New to the forum gang... just got a 84 K5 on big lift on 35in swampers. Love th truck so far. Question... I'm adding a tach, have everything done but the dimmer light...tach is working. Can't find the right wire to tie into to....(so the tach lights up at night) any help would be great.
Old Dec 18, 2009 | 07:44 PM
You should be able to find the proper wire at the headlight switch. Use a test light to determine which wire gets +12V when the headlights are on. It should be the dark green wire at the headlight switch.
Old Dec 18, 2009 | 08:49 PM
84_K5's Avatar
Thanks! Is there an easy way to get to the wire? I looked under the dash... can't make it up that far. I guess the I could take the light **** off and pull the thing out forward?
Old Dec 18, 2009 | 08:55 PM
Drop the panel from under the steering column and you should be able to get up there.
Old Dec 21, 2009 | 12:16 PM
84_K5's Avatar
it worked, got it fixed. Big thanks
radiokid
May 18, 2010 07:26 PM
Jonas
Apr 8, 2010 01:12 PM
JShark
Feb 5, 2010 12:30 AM
blazerxtreme1
Jul 29, 2006 04:45 AM
blazerxtreme1
Jul 8, 2006 05:41 PM
