Please help!! Oil leak!!
Old Feb 16, 2012 | 12:05 AM
choover82's Avatar
choover82 is on a distinguished road
Originally Posted by Chevy33
The oil lines are prone to failure. Make sure you have proper oil level and clean the suspected area. If you do need to replace the lines to the remote filter, do both at the same time. It is easier to remove and install the line to the block if you jack the motor up a bit.
Does one need to remove mounts to lift motor? Mine has leak in what looks like both lines, filter/motor and filter/radiator...only a few drips after its been running (that I can see on dip stick)
louiepb
Jan 7, 2012 09:34 AM
Patrick3217
Aug 24, 2011 10:31 PM
cory.kiel
Apr 20, 2011 06:52 AM
87Blaze
Apr 17, 2011 08:01 PM
jiggs240
Apr 15, 2011 03:09 PM
