Plugs & Coil replacement
Old Jun 5, 2011 | 08:57 AM
  #21
JerryB52's Avatar
JerryB52 is on a distinguished road
Unhappy
Okay, fuel pressure went to 50 psi when I cranked it over, then within 5 to 10 seconds, dropped to nothing...
It's the regulator and nut kit, right?
Old Jun 5, 2011 | 09:09 AM
  #22
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
It could either be the fuel pressure regulator, the check valve in the fuel pump or the little piece of hose connecting the pump to the hanger assembly.
Old Jun 5, 2011 | 09:27 AM
  #23
hubert hefner's Avatar
hubert hefner is on a distinguished road
pull the plenum off and turn the key on and you will see the leak. the plenum is easy to get off. alot of times the lines get a hole in them or the FPR goes bad.
Old Jun 5, 2011 | 11:20 AM
  #24
chris015's Avatar
Yes
The check valves are usually pretty good with these pumps. This problem he is having is 99% of the time is the regulator or nut kit in these certain vehicles. It could still be the check valve etc but i highly doubt it.
JavierEscalonJr
Oct 14, 2020 11:38 PM
jkyle187
Feb 15, 2015 08:45 PM
blainenbecky
Mar 9, 2013 10:38 PM
Lancealot
Feb 22, 2011 07:34 AM
skoot61
Feb 19, 2008 11:20 AM
