rapid turn signals
Old Feb 3, 2010 | 05:31 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
thats happens because of the current that they use. i have an 86 and it does the same thing.
Old Feb 18, 2010 | 12:43 PM
4x4VegasDan's Avatar
4x4VegasDan is on a distinguished road
I see. It never did it before just recently. I still have yet to get in there and look. Sorry no update. But now my drivers side door jamb switch makes the horn blare when you open the door. I do not know if it is related to the blinkers or not. Seems like something must have shorted out.
Old Feb 26, 2010 | 01:55 PM
longislandboy's Avatar
longislandboy is on a distinguished road
just joined today and this is my first post. lucky you :-) have you checked all the bulbs that flash when the signal is turned on? That used to be a dead give away years ago that there was a bulb out somewhere. regarding the new problem - does the interior light come on when you hit the horn? it's an odd question i know, but may give an insight to the cause. see what happens with the fast flashing first - once that is solved go on to the horn issue. does it also happen when the passenger door is opened?
Old Mar 1, 2010 | 08:26 AM
I do not know if the interior light works or not. I have not had a bulb in since i first bought the truck. I was having quite a few electrical problems then. I have had the dash rewired and did not bother putting a bulb back in. I can tell you that it was only with the drivers door open. I have checked all the bulbs. One did burn out. I replaced it. It was still rapid but currently is at normal speed. The volts still twitch in sequence with the signal though.
bella313
Aug 16, 2015 09:12 PM
SubbinBlazer
May 24, 2013 12:56 PM
loblzr
Lowering Tech
Mar 13, 2011 08:27 PM
mikesansone
Jun 15, 2010 02:04 AM
blazin97
Feb 22, 2005 01:49 AM
