Rear glass / trunk won't lock?
Old Aug 23, 2012 | 09:43 AM
ruxpin76's Avatar
ruxpin76 is an unknown quantity at this point
Default Rear glass / trunk won't lock?
While going over routine maintenance and cleaning, I discovered that my 1993 Blazer's rear glass wouldn't lock. It shuts and latches fine, but the exterior "t" handle with the lock cylinder behind it can be turned to open the glass without the key. This occurs whether the vehicle's driver's and passengers' doors are locked or open. I figured it must be the cylinder, so I replaced the unit ($20). To no avail.... Suggestions? As said earlier, it latches fine, just won't "lock". Advice appreciated as I need a secure vehicle. Thanks!
Old Aug 23, 2012 | 09:45 AM
chris015's Avatar
the aftermarket units suck. ive gone through 3 on mine in no time. All of them stop locking. Return the new one for another one and try it again.
Old Aug 23, 2012 | 01:29 PM
ruxpin76's Avatar
Sucks alright! I discovered that the "pin" that retracts when you insert the key doesn't go out far enough to catch reliably to stop rotation, and its' corners are rounded to top it off. But to discover that, I lost the two springs that push it down. After a beach trip this weekend (where it will stay locked as it can't open) I'm exchanging it.
Old Aug 23, 2012 | 04:46 PM
richphotos's Avatar
Mine does not lock either, but to be fair, previous owner got the gate from someone in TX cause its rust free, and removed the tumblers instead of getting it re-keyed. I think I might just bite the big one and get one from rock auto. Apparently re-keying a new one to use your previous keys is pretty easy.
Old Aug 27, 2012 | 01:56 PM
Matthew Hayes's Avatar
Matthew Hayes is on a distinguished road
I guess I can consider myself lucky as mine works fine. (for now)
The only thing that doesn't work is the electric unlock for the glass.
Old Aug 27, 2012 | 04:22 PM
ruxpin76's Avatar
Trying #3 from NAPA. Balkamp part. We'll see if the third time's a charm.
Old Aug 27, 2012 | 04:34 PM
richphotos's Avatar
I picked up a OEM gate lock from the u pull this past weekend, had a key in it too, and it works, for 2.50, Worth a try on seeing if your local upull has one.
scosentino88
Jun 3, 2012 07:12 PM
AllegedGangsta
Apr 4, 2012 06:55 AM
rasputinlv
Nov 10, 2010 07:53 PM
hawaiiboi808
Jul 11, 2007 07:19 AM
bbunn1
Apr 13, 2006 03:58 PM
