rear window(tailgate glass) button?
what exactly does this do?(i have a 94 blazer) i press it and it sounds like it unlocks it. is that what its for? if so i think the ock is sticking because it still requires the key to open
Mine does the same thing because the gate is sprung placing pressure on the glass which puts a load on the latch and the electric solenoid is not powerful enough to overcome the load.
Have someone place a little pressure on the glass while you press the unlatch button. If it unlocks then you probably have an issue of excessive load on the latch.
ok thanks. lol you always answer my questions. thanks for that
No problem. I have been given help on here and the best repayment is to give it back on here to others.
I will try thanks
I'm on my third gen, blazer. A nice 93 4x4. When I would press the latch unlock it sounds as if had unlocked but it didn't. I had to use the key. I removed the access. unbloted the solenoid which pulls the latch, and moved the solenoid away from the original bolt holes about a bolt hole away. viola!
blazen_red_4x4
08-02-2020 03:18 PM
scosentino88
06-03-2012 07:12 PM
