Rubber fuel lines
Old Oct 3, 2013 | 09:54 PM
odat's Avatar
i happen to have the cpi vortex - no steel lines ran on frame - rubber hose clamped to the short steel line on the tank then attach too the short steel line over the transfercase - just cut off the flair nut off the line on the tank and the old rubber hose off the steel line and hose it
Old Oct 3, 2013 | 10:38 PM
richphotos's Avatar
There are steel lines ran on the frame, if you do not have steel lines, someone did some work, I have steel lines from where it turns rubber at the fuel pump, to the fuel filter, and over the transfer case.
Old Oct 4, 2013 | 01:08 PM
odat's Avatar
yes there was steel lines at one time -mine were about deterated into - i ran rubber from tank to filter then from filter to the line above transfercase -return and vent steel lines were bad also so i ran all rubber there also - in most cases even standard fuel line is rated at 50# and higher - injection line is at 180# and higher - make sure you slide the hose over the steel line at least a inch or two and clamp it -
Old Oct 5, 2013 | 10:12 PM
exalteduser's Avatar
exalteduser is on a distinguished road
I ended up getting some 5/16 steel line and used compression fittings. had to cut the flare off the sending unit, and ran about 1 1/2 feet of it, picked a spot and cut the old line. compression on both sides, no leaks after 1 test drive. now my exhaust comes in the floor hole though lol, duct tape time!
thanks for the help guys
spatula6554
Apr 10, 2012 02:17 PM
dj00140
Apr 13, 2011 10:48 PM
Phre4k
Jun 2, 2006 02:40 AM
kaindragoon36
16
Mar 30, 2006 11:13 PM
