Running with no cat...
Old Sep 28, 2010 | 06:36 PM
88_s10's Avatar
88_s10 is on a distinguished road
Question Running with no cat...
Would having no cat on an 88 4.3 effect how it runs? Just picked it up, owner before put hedman headers on it (don't know why), pulled the cat, and put on what looks like a flowmaster muffler. Theres still the o2 sensor in the exhaust at the Y in the pipe.
thanks
Old Sep 28, 2010 | 06:58 PM
No, it should not cause it to run poorly. You may have problems getting it inspected, but I'm not sure how things like that work in BC, CA.
Old Sep 28, 2010 | 08:40 PM
machineto0l's Avatar
machineto0l is on a distinguished road
Mine has an empty cat.. works fine.
Old Sep 29, 2010 | 12:52 AM
88_s10's Avatar
Ok cool. Just wasn't sure if it would make the o2 read differently, but I guess thats just in OBDII cases, and even then secondary o2s will only trigger the CEL. As for inspection, I've just got it registered in an area that doesn't require stupid aircare like it does in the lower mainland.
thanks!
Old Sep 29, 2010 | 10:23 PM
abig84's Avatar
only times i ever heard it causing problems is if the sensors are behind the cat. i had to remove mine when i built my 93 cause it was in the way of the transfercase i used.
Old Nov 19, 2010 | 07:32 AM
godfatheritalio's Avatar
godfatheritalio is on a distinguished road
Cool
Removing my cat caused my car to drive more efficent and my previous cat wasn't damaged or clogged in any way. not much of a difference in power but flow i can guarentee. as long as no o2 sensors are behind the cat you won't have any triggering codes. and on the 4.3l come to think of it there isn't any o2 sensors behind the catalytic converter. and it made my car sound deeper with my set up.
Old Nov 19, 2010 | 07:53 AM
The old pellet style converters used up into the late 80's & some early 90's vehicles were very restrictive. The newer honeycomb style catalysts are much better in terms of flow and do not hinder performance/efficiency like the old ones did.
In the end, be responsible.
hillbillys10
Apr 14, 2013 01:04 PM
Squad-6
Headers, Intake, & Exhaust
May 17, 2011 10:29 PM
Bullfrog2099
Dec 16, 2010 07:25 PM
PaulO2288
17
Jan 20, 2010 01:39 PM
djbass_mekanik
Apr 22, 2006 06:15 AM
