To rusty to read
Old Jan 25, 2013 | 03:48 PM
2bejustme's Avatar
2bejustme is on a distinguished road
Default To rusty to read
There are 2 arrows and 2 vallies. To find tdc ,the markings are to rusty. Have installed new head gaskets and need to set at TDC. This way I can install distributor shaft correctly. A pitcure would help alot.When #1 is at TDC should it be flush with the block deck, or recessed a little bit. Also do I rotate distributor shaft to line up with #1 inside of distributor cap. 1993 s-10 blazer 4.3l TBI vin z
Thank You
Old Jan 26, 2013 | 10:08 AM
abig84's Avatar
if you have the #1 piston at top dead center the crank notch should be in the deep valley on the gauge, like it should have two valleys then a deep one. also mark that notch on the crank with a white marker so you can see it easier in the future. and while you are spinning the distributor while setting the timing
thats the best picture i can find
and yeah if the engine is at TDC the rotor should be pointing onto the number one cylinder
Attached Thumbnails To rusty to read-0901rc_09_z-pertronix_flamethrower_distributor_chevy_engine-stock_tab_2.jpg
Old Jan 27, 2013 | 05:54 AM
2bejustme's Avatar
I want to thank you very much. That is what my timing pointer looks like. I will move it 1 more valley over to the deepest one.A pitcure is worth a 1,000 words.
kevinph
Feb 25, 2019 09:24 PM
carterx
Sep 23, 2009 06:17 AM
BlazerSS
Detailing
Mar 17, 2009 10:18 PM
Bad Ramer Jamer
Sep 22, 2008 10:29 AM
jeffale5
Feb 27, 2008 09:45 AM
