Service Engine Soon (The Oh SH@* Light)
well im talking about jumping it actually with the special key or like a paperclip. If your talking about an acual scanner you may be right
i would say check vacume line to egr and clean also
paperclip it. The onboard computer stores codes and itll tell you. just straighten a paper clip and then bend it into a U shape. Stick one end in each of the two upper right holes of the OBDsocketwhile the engine is off, then turn it to "run" position and the check engine light will flash codes at you. itll read 12 three times, then any codes that are stored in it.
In MY truck, if i put too much lateral force on it i get a check gauges light and that could cause some codes to be thrown if something reads out of the ordinary.
amello1
01-02-2006 01:14 AM
TwilightEpitaph
08-11-2005 01:06 AM
gmyoyo
Engine & Internal
03-29-2005 12:17 PM
