Shifter Lever broke
Shifter Lever broke
So the shifter lever is broken on the steering column, and I dont really want to buy a new one... Does anyone know of a creative way I can repair this?
It works. It just comes out of where its suppose to be secured. There are no issues shifting. I would leave it but when i hit it or go over a bump it pops out and goes on the floor.
Someone tried to tack weld = fail
"Mighty Putty" = fail
I'm open to try anything that you think will work.
i beleive there is a pin type thing that holds the shift lever in place so you could just buy a new pin to hold it in place or rig up your own pin to keep the lever in place.
You know, that's the weirdest looking Blazer I have ever seen.
What has failed here? If it is the type of failures I have seen, the collar on the steering column actually breaks out where the pin is held in place. If this is what has happened, the only real way to fix it without really cobbing something up is to replace it. You would probably be surprised at what a junkyard column would cost.
Thats exactly what happened. I looked on Ebay and all I could only find would be 100+
I'll check junk yards
Thanks
bring up my old thread, will this fix my issue?
http://www.autozone.com/autozone/cat...Name=Lockworks
i don't know what the wreckers around you charge, but i can p/u a coluum for $50, and that's Canadian, hahahaha! did the coluum break off, or did the bottom of the shifter arm?
The part where the pin goes to hold it in, the plastic on the column
yeah, i though it would be the collar (i've only ever seen one lever actually break before-that'd be me ). check your wreckers, they should be easy to find one.
matthewp
04-04-2021 09:16 PM
jasedude
11-24-2010 04:03 PM
terry2707
01-10-2010 06:42 PM
