shorted out blazer help
Old Jun 10, 2008 | 09:36 PM
coolbrother2002's Avatar
coolbrother2002 is an unknown quantity at this point
Default shorted out blazer help
i got a 94 blazer and my parking lights dont work............until i press the brakes...its kind of weird. how can i go about fixing it....im not sure where to look but all my fuses are good....any advice would be aprecaited...thanks...
Old Jun 11, 2008 | 12:15 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Default RE: shorted out blazer help
had a 93 with a similar problem once-take the rear taillight out and bare the black ground wire going to the lamps(pkg) and temporarily run another ground. If that works you've lost the ground for that circuit you'll need to run a new one. In my case I just ran a new one within the taillamp cavity. good luck jp ps you may have to do it to both sides!
Old Jun 11, 2008 | 05:24 PM
ok well, its not the ground its the hot wire, i took some speaker wire and hooked it to my batteryto the middle small bulb, which unless im wrong is the running lights, the brake lights and running lights come on on both sides...this is wierd...
Old Jun 14, 2008 | 07:10 PM
guess there arent to many electricains in this place...thanks for the effort peru
TH2kBlazer
Jun 3, 2015 08:58 AM
antman94
Dec 7, 2013 09:06 PM
BlackBastard
Jul 7, 2011 11:31 PM
ChevyBlazerChick
Aug 26, 2009 08:12 PM
ESKYMOPACK
Jun 20, 2009 07:16 PM
