tailgate issue
Old Sep 24, 2012 | 01:37 PM
wheeliemay's Avatar
wheeliemay is on a distinguished road
Default tailgate issue
Hey everybody. I'm pretty new to the forum so please forgive me if this is in the wrong area...1994 Blazer Z71 tailgate glass shuts very hard--but just slamming it won't necessarily close it. It is like the glass is not attached to the window frame at the bottom. When it does close, the glass can be lifted away/separated about 1/2 inch without unlatching the gate. So I'm looking to see if I need to adjust the closer portion that latches into the latch (mounted to bottom of tailgate glass) or if I need to try to reinforce the area at the bottom of the glass. Any experience or suggestions would be appreciated.
Old Sep 24, 2012 | 03:52 PM
ohsofly's Avatar
Adjust the latch in the lower gate.
Old Sep 24, 2012 | 04:37 PM
wheeliemay's Avatar
does that require removal of the interior panel? Thanks
Old Sep 24, 2012 | 05:31 PM
chris015's Avatar
yep,pull that off,and you'll see the flange,with 2 10mm bolts. loosen em and adjust as necessary. Best way to do it is get a friend to lock you in there,close the tailgate and adjust from inside. If you dont get it good and tight against the window it'll squeak and drive u nuts.
Old Sep 25, 2012 | 11:51 AM
NCSurvival's Avatar
NCSurvival is on a distinguished road
I would mark the latch before you readjust it, just in case that's not the problem. You can also loosen the posts on each side that the tailgate latches to. They take a large torque tip bit to loosen. It will give you about a 1/4" or more to adjust. I am sure they adjust forward or back. My Blazer does.
RobRad
Mar 24, 2014 06:08 PM
88 rusty but trusty
Dec 21, 2009 08:28 AM
kwerts
Nov 4, 2009 07:13 AM
stlblueblazer
Aug 29, 2005 10:56 PM
sleonh
Mar 29, 2005 03:32 PM
