Temp gauge fixed Now for the next problem
Basically whenever i hit a bump or expansion joint my front end has this loud "thump" to it. If you drive steady all you will hear is the tires singing and the vehicle tracks straight. I already replaced the lower ball joints and the idler arm. What else could cause this?
Upper balljoints, although it shouldn't be as loud as a lower, a broken swaybar link, possibly a loose or worn shock (but that's stretchin' it). You should also see if your hood hinge bolts are loose. This can cause close to the same sound as a ball joint only up higher.
zakm0n
01-09-2011 07:31 PM
Imperator
04-07-2010 05:05 PM
trampaslake
02-04-2009 11:24 PM
mboehler
01-16-2009 07:16 AM
