timing 2.8l 87 fuel injected!!
Old Nov 9, 2009 | 04:47 PM
d8d's Avatar
d8d
d8d is on a distinguished road
Default timing 2.8l 87 fuel injected!!
what is the timing for this beast??
Old Nov 10, 2009 | 09:56 AM
neo71665's Avatar
10 degrees advanced
Old Nov 10, 2009 | 01:33 PM
d8d's Avatar
d8d
right on thx a ton..
my blazer is just getting terrible fuel milage, a full tank will get me 350km which shouldnt happen.
i think its my timing but not 100% sure tho.
i get a check engine light for about 20 seconds after its been drivin for an hour or 2 but then will go off, i tried with a code reader and it doesnt pick up anything, i have no idea why im gettin such bad milage. i tried 02 sensor and still got terrible milage, could i possibly be the MAP sensor, or EGR valve??
its really slugish to once the vehicle is warm thats why i think it might have sumthing to do with the emission system on this beast..
Old Nov 10, 2009 | 03:46 PM
neo71665's Avatar
I only get about 18 or so in mine.
Old Nov 11, 2009 | 01:52 PM
13ogart's Avatar
13ogart is on a distinguished road
im going threw the same deal with my 88 2.8L the fuel is crazy i get 400km to a tank i never thought about the timing though my EGR is new ive also put a new fuel pump in.. im planning on changing spark plug wires, cap and rottor, fuel filter.. and see where that gets me ill be happy with 500km per tank.. if you figure it out let me no what you did because mine blazer even has the same symptoms as yours..
Old Nov 11, 2009 | 03:04 PM
neo71665's Avatar
Well I hate to say it but if you are replacing the EGR and using some parts store brand (not AC DELCO) they are known for not operating 100% correctly. They work well enough to not throw a code but stay cracked just enough to still allow exhaust gases into the combustion process.
I'm glad I aint got emissions testing here. I'm just gonna delete the egr and AIR pump from my ECM.
Old Nov 11, 2009 | 04:11 PM
13ogart's Avatar
Also i still have to replace the inner tie rod and idle arm i believe its creating alot of drag on the truck has any one done that and seen an increase in fuel mileage ?
Old Nov 11, 2009 | 06:00 PM
neo71665's Avatar
Unless its just so bad its not road worthy I doubt you see much of a change. Make sure you have it aligned after.
Old Nov 11, 2009 | 10:37 PM
d8d's Avatar
d8d
yah i only get 100km for 20$$ like 300km to 350km is just terrible its really bad i need to figure sumthing out
Old Nov 12, 2009 | 06:41 PM
d8d's Avatar
d8d
i still havent figured this problem out yet. tried timing it but i did it wrong, i forgot to pull the plug from the bottom of the distributer so it wont advance timing when i check it...im pretty sure its that plug to stop the EST from kickin in...
EGR valve when they dont work will it throw a code for only a few seconds once the vehicle is warm.. it only seems to flick on when im going around 70-75kmh then will go out? this is weird to me, it seems pretty hesitant once warm to... it must be a EGR valve, or timing, or map sensor i think
