timing
Old Apr 8, 2007 | 09:33 AM
bigt's Avatar
bigt is an unknown quantity at this point
Default timing
Can someone tell me how to check the timing on a 1984 2.8 v6. The motor won't start so I can't use a timing light. Sometimes it will backfire through the carb Thanks
Old Apr 9, 2007 | 12:49 PM
filstoy's Avatar
filstoy is an unknown quantity at this point
Default RE: timing
I'm assuming you want to know how to get the distributor in right since you say it's backfiring and you can't check it with a timing light. This should cover it.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Apr 10, 2007 | 06:16 AM
lunatic_magnet's Avatar
lunatic_magnet is an unknown quantity at this point
Default RE: timing
turn the distributor little by little until it WILL start, then use a timing gun.
time it immediately after you get it running, if you let it run for 3~4 minutes with the timing off you could make things very hot under the hood. exhaust manifolds like to glow red if the timing is off...
Doctorvette
Nov 5, 2012 11:57 PM
Denominator
Sep 23, 2010 02:40 PM
hotrodln
17
Apr 26, 2010 07:32 PM
Denominator
Apr 25, 2010 06:31 PM
bwhite
Feb 4, 2010 08:28 AM
