Timing Marks
Old Feb 23, 2015 | 08:06 PM
TheRemedy's Avatar
TheRemedy is an unknown quantity at this point
Default Timing Marks
I recently was adjusting the timing for my 1989 Chevy S10 4.3L engine. During the process, I realized I don't know for certain which mark or notch designates the 0° mark, and I can't tell if there is an engraving that I missed. If anyone knows for certain, please a take a look at the photo and provide input. It seemed to be around position E or F.
Thanks
Old Feb 23, 2015 | 10:45 PM
Blazin_Jason's Avatar
Deep notch should be 0, link.
Old Mar 3, 2015 | 01:37 PM
abig84's Avatar
yeah the big valley you labeled F is 0. and each up and down point is 2 degrees
Old Mar 25, 2015 | 03:37 PM
Brian K. Balzer's Avatar
Brian K. Balzer is on a distinguished road
Default Timing Grooves
I'm not quite there yet but I'll likely have to set the timing on my son's 85 Chevy S10 with a 3.1 (out of a 91 Camaro). I've been wondering which groove on the harmonic balancer is going to be the correct one to use as zero. It has (technically they both have, 2.8 stock & 3.1 going in) two thin grooves and one fat one. So far the best answer I've gotten is to bring the number one to top dead center and the groove under the 0 on the timing guide is the correct mark.
Old Mar 28, 2015 | 03:44 PM
TheRemedy's Avatar
Position F worked for me with the 4.3, not sure about the 3.1.
Old Mar 28, 2015 | 09:02 PM
IF I'm not mistaken, (I've slept since I looked last), the timing gauge on the 2.8 timing change is marked with 0 and the degrees. What I'm not sure about is which mark to use on the harmonic balancer. Not sure it'd be the same as on a 4.3 though. That'd be too easy.
bertrenolds
Nov 25, 2011 08:51 PM
dealrocker
Detailing
Jul 2, 2010 02:03 AM
thehustler211
Apr 1, 2009 03:30 PM
picinisco
Oct 28, 2008 01:52 PM
spib
Street N Strip
Aug 11, 2007 09:46 PM
