Timing setting
Timing setting
I have a 92 s10 Blazer with W engine. I had to pull the dist. When I reinstalled it I could find no info on what to set the timing to. I had to do it by ear. There is no label or info in the engine compartment giving that info like there should be.
Does anyone out there know the the proper setting.
Thank you.
Thank you.
You first have to disconnect the brown timing wire that is off the passenger side of the transmission tunnel at the firewall inside the cab. You can then set the timing with a light to 0* TDC #1
Once you set the timing and have reconnected the brown wire you will have a MIL light on. Disconnect the battery for a few minuets and reconnect the battery and the MIL light should be extinguished.
riddikstraaf
08-08-2010 05:14 PM
A2Zcustomupholstery
08-04-2010 08:07 PM
justin1795
03-27-2009 07:55 PM
