Transmission fluid leak
Old Jul 20, 2018 | 08:33 AM
Bepjer28's Avatar
Bepjer28 is on a distinguished road
Default Transmission fluid leak
An odd thing has happened with my 03 blazer 4dr ls... I had it parked in my in law's garage for a couple of months and nothing... When I moved it to the driveway a day later there is a puddle of transmission fluid underneath it... Why would that happen and is there a frequent place they leak from?
Old Jul 21, 2018 | 04:22 PM
chevyriders's Avatar
I would start by checking the transmission cooler lines. They run from the passenger side of the transmission, along the engine oil pan, and into the pass. side of the radiator. They have a tenancy to rot out over time, especially where the lines clamp to the side of the oil pan.
Old Jul 21, 2018 | 05:34 PM
Bepjer28's Avatar
Thanks... I'll have to check that after i fix the parking brake so i don't run myself over...
Old Jul 21, 2018 | 06:45 PM
Where is the leak under the truck exactly?
If it's towards the front as in under the radiator area, could be coming from the cooler lines where they go into the rad. If it's directly under the middle of the truck where the trans is, could be the cooler lines as suggested by chevyriders, could be the main output seal at the drive shaft.
Old Jul 21, 2018 | 10:14 PM
Bepjer28's Avatar
Looks more like right under Where the engine/tranny joins..
Old Jul 22, 2018 | 01:30 PM
You're certain it's trans fluid, not engine oil right?
The lower intake gaskets are known to leak on the back side and run down the back of the block where it meets up to the trans and cause many people to jump straight to a rear main...
Old Jul 22, 2018 | 01:57 PM
Bepjer28's Avatar
Yeah engine oil is good... If I don't add transfluid sometimes it won't go but other's it slips around 55 mph
butcher321
Dec 2, 2015 01:17 PM
NCSWP
Sep 9, 2014 12:15 PM
bogborn
May 22, 2012 09:37 AM
4x4blazerguy
Jan 19, 2012 06:53 AM
Mr Blazer LT
Jun 5, 2007 07:30 PM
