Turn Signal Issues
Old May 27, 2009 | 05:59 PM
91chevywt's Avatar
91chevywt is an unknown quantity at this point
Default Turn Signal Issues
So I'm having some turn signal issues in my Jimmy. Heres a list of the symptoms
-Turn signals won't cancel
-Left turn signal lights up but does not flash
-Right turn signal operates properly
-One bulb is burned out on the left side (left front bumper), one bulb is burned out on the right side (right front corner), I'm pretty sure its just the bulb that needs to be replaced.
-When putting on the 4 ways, all lights flash at the same speed (except the burnt out bulbs)
I would think that the flasher might be the cause of the turn signal just staying lit, but I would think that the right would stay solid also. So, where should I start? I was going to look at the bulbs to see what is up with them and check out the sockets also.
Old May 27, 2009 | 06:12 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
You should definitely fix the bulbs first. The cancelling issue is a problem inside the column, probably the turn signal switch itself, because the cancelling cam really can't go bad in this respect. fix the obvious first (blown bulbs) then repost.
Old May 28, 2009 | 01:44 PM
91chevywt's Avatar
Ok so I replaced the burnt out bulbs, and now both sides flash. As far as the turn signals not canceling, I wasn't sure if I should be looking to replace the turn signal stalk or the turn signal cam...and at that I'm not really sure how to do either
SubbinBlazer
May 24, 2013 12:56 PM
ta3ff
Oct 14, 2009 05:07 PM
jimmy2blzr96
May 11, 2009 09:32 PM
jmills
Apr 16, 2008 08:47 PM
shaka1111
Feb 13, 2006 02:23 PM
