upper ball joint removal
Old Jul 8, 2012 | 11:59 AM
bikernutgoofy's Avatar
bikernutgoofy is an unknown quantity at this point
Default upper ball joint removal
does any one here have a video or a good description on removing the upper ball joints on a 1992 S10, 4x4 Blazer. I am about to attempt this but would like some good directions, I have use of air tools, lift, and OTC u joint press with ball joint adapters do the axles have to be removed or better yet what has to be removed to make this go some what easy?
Thanks for any or all info.
Old Jul 8, 2012 | 05:34 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Take off the wheel. Unbolt the ABS sensor. Pop the ball joint from the steering knuckle with a ball joint removal tool or a pickle fork and BFH.
Chisel off rivet heads, drill out rivets enough to drive out with BFH and large punch.
Install new ball joint, bolt heads on the underside and nuts topside (won't chew up the steering knuckle this way). Put steering knuckle under new ball joint and jack up with jack until the threads stick through, then install castle nut and torque to specs. Tighten as needed to line up cotter pin holes, then install cotter pin.
Make sure you have reinstalled the ABS sensor bracket when you bolted the ball joint to upper control arm. Reinstall wheel.
Old Jul 8, 2012 | 10:55 PM
50percentgenius's Avatar
50percentgenius is on a distinguished road
Dieselcr7
Jan 12, 2012 07:23 AM
mr.vls
Sep 8, 2010 05:34 PM
megtom2
May 31, 2010 12:13 AM
bswitz
May 30, 2010 09:23 AM
Elwood
Sep 28, 2009 11:57 PM
