Help with upper ball joint castle nut tightening
Old Jun 19, 2011 | 12:24 PM
Dieselcr7's Avatar
Dieselcr7 is on a distinguished road
Default Help with upper ball joint castle nut tightening
Hi all. Hope I'm posting this properly.
I have a 97 Blazer 4x4@ 205000km. I'm replacing all 4 original ball joints with power performance.
My problem is tightening the upper joint castle nut. The cotter pin hole is lined up but the castle nut is very loose and there is a gap between upper control arm and steering knuckle. I can't figure out how to properly torque the castle nut and close the gap. Everything else is tightened down and installed. Any help would be greatly appreciated. Thanks.
Old Jun 19, 2011 | 09:28 PM
Little Roober's Avatar
Little Roober is on a distinguished road
Did you use a torque wrench and torque it to the correct ft pounds? Then tighten it a little more to line up the cotter pin holes. That's exactly what I did on my 96 4x4.
Old Jun 20, 2011 | 11:16 AM
Dieselcr7's Avatar
Yes, I was able to torque the castle nut properly and line up the cotter pin hole. Thanks.
These power performance (Pro Forged is new name I believe) are a very nice product. I do have one question with the upper. It came with a snap type ring, not sure where on the ball joint the ring goes?
Old Jun 20, 2011 | 05:35 PM
It goes around the top part of the rubber. Right under the lip to hold the rubber in place and keep the grease in.
Old Jun 21, 2011 | 12:11 PM
Dieselcr7's Avatar
That's what I thought. Just wanted to be sure. Never used ball joints like these. Im almost done installing, can't wait to get aligned and get driving on em.
Thanks for the info.
Old Jun 21, 2011 | 06:58 PM
Dieselcr7's Avatar
So I have everything back together. I'm just not positive that the steering knuckle and hub assembly are seated all the way back into place. There is a very small space (about an eighth inch) between the assembly and cv boot. It seemed tighter before I dismantled it.
Just want to be sure I have it right.
Old Jan 2, 2012 | 09:40 PM
Scorpious's Avatar
Scorpious is on a distinguished road
hey i just did mine and same thing, small gap between boot and arm..
this cause any problems for you?
Old Jan 11, 2012 | 04:45 PM
Dieselcr7's Avatar
Hey. Sorry, i just saw your post.
Its been 5 or 6 months and no problems.
Did everything work for you?
Old Jan 12, 2012 | 07:23 AM
Scorpious's Avatar
Well haven't broke yet. LOl
lamarche499
Jul 16, 2013 01:46 PM
mr.vls
Sep 8, 2010 05:34 PM
megtom2
May 31, 2010 12:13 AM
bswitz
May 30, 2010 09:23 AM
Elwood
Sep 28, 2009 11:57 PM
