wanting to change brake fluid, ok to mix synthetic?
Old Oct 3, 2009 | 03:27 PM
rastoma's Avatar
rastoma is on a distinguished road
Default wanting to change brake fluid, ok to mix synthetic?
I'm going to try and flush the brake fluid in my truck. I'm sure it's never been replaced. Is it ok to use Synthetic as I flush? Is it a problem if I don't every drop of old fluid out, is it ok that the two mix together?
Also, while I'm at it, I will be doing a trans flush soon.
Same thing.. is ok to mix?
Old Oct 3, 2009 | 03:40 PM
bandidolenny's Avatar
yes... you can mix them as long as they are both DOT 3 or whatever your vehicle calls for. Same for the tranny.
Old Oct 4, 2009 | 12:06 AM
BusaJoe's Avatar
BusaJoe is on a distinguished road
Unless they have come out with a Dot 3 Synthetic don't do it.
The only synthetic I've seen is Dot 5.
Most tranny fluids are compatable.
Old Oct 4, 2009 | 07:41 AM
rastoma's Avatar
So dot 3 and dot 5 are not compatible?
Old Oct 4, 2009 | 09:37 AM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
^ correct, DOT 3 and DOT 5 are not compatible.
Old Oct 4, 2009 | 01:27 PM
Hence... you can mix'em if they are both the same DOT rating.
Old Oct 7, 2009 | 05:47 PM
rastoma's Avatar
I double checked, I got DOT 3 synthetic.
Sucked out the fluid from the master cylinder resevoir... was almost black as oil.
BrinkDiamond
Mar 2, 2014 03:50 PM
DaleA
Jan 13, 2009 08:50 PM
Syres1
Oct 12, 2008 02:13 PM
TripleBlackBlazer
Feb 27, 2007 11:10 PM
Hanr3
Engine & Internal
Sep 8, 2006 02:31 AM
