Will not start
Will not start
94 s10 blazer 4.3 vortec "W" vin. We are at our wits end with this truck! It will crank over but will not start unless you spray either in the plenum. We have replaced the fuel pump twice, the computer, sensors, spider injector, pick up coil, plugs, wires, ignition switch. You only hear fuel pump come on when it's cranking and accessory doesn't work. The key is very worn and sometimes it's hard to tun. Would the ignition lock cylinder stop it from starting? I don't know what else to do. Anyone know of what else to do?
i'm fairly sure i have a factory pump on mine. when the key is turned on, you can hear an initial wine of the pump priming, and then it's quieter.
you're sure you're getting fuel?
could the fuel pressure regulator cause an issue this grand?
a lot of these guys on the forum call for a leak down / fuel pressure test. i believe 55 psi or thereabouts consistently and after ten minutes worth of running is desired.
stschuyler25
11-21-2010 09:34 AM
wayland
12-09-2009 12:38 PM
blazerJim1701
07-26-2009 09:18 PM
actionpaintball
07-14-2006 07:53 PM
apekim
06-30-2006 10:38 AM
