Wont Start????
Old Feb 24, 2011 | 01:41 PM
sutterdan's Avatar
sutterdan is on a distinguished road
Default Wont Start????
I have an 87 S10 Blazer it wont crank it sounds like a bad battery or starter when u turn the key there is nothing, replaced battery, starter, alternator, cables, and checked grounds. Still wont start any advice would be great
Old Feb 24, 2011 | 05:44 PM
burning_soul07's Avatar
burning_soul07 is on a distinguished road
Does the starter even try?
Does it try but nothing?
If it tries, does it have spark and fuel?
Even if it has spark, are the plugs clean?
If it doesn't even try, can you jump the starter by hand to try it that way?
Maybe theres a wiring issue in the column to the computer...
Too many variables.
Old Feb 25, 2011 | 02:58 PM
sutterdan's Avatar
no it seems like their is no power going to the starter acting like a dead battery
it gets spark good plugs
dunno about fuel havent checked
i have jumped the starter and its good i blew though 2 of them since it was burning them out
i know it must be some electrical issues but dont know where to begin
Old Feb 25, 2011 | 04:22 PM
ffox's Avatar
ffox is on a distinguished road
I don't understand how you're burning them out. Are you sure your motor is not locked up? When you jump them they should kick in and turn the motor if they're good. They're 12 volts, and if you're jumping them with 12 volts it shouldn't be burning them out.
Try turning your lights on and hitting the starter switch, if they go real dim you've either got a short in the starter circuit, a bad battery, motor's locked up, or the starter is shorted.
Old Feb 28, 2011 | 01:02 AM
sutterdan's Avatar
i wish i could hit the switch and see if the headlights dim but i have no headlights they dont even turn on but the tail and brake lights work
Old Mar 1, 2011 | 12:21 PM
mxpxpunkrock1987's Avatar
mxpxpunkrock1987 is on a distinguished road
bad relay or short in the ground to body or the switch is bad
Old Mar 1, 2011 | 01:00 PM
theonetruetom's Avatar
theonetruetom is on a distinguished road
Check the cable that goes from the engine to the chassis and the ground from the body to the chassis. If those are gone or broken, it'll seem like it's completely dead.
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
slammed95blazer
Oct 27, 2010 07:24 AM
jetsmy
Aug 1, 2008 10:10 PM
