Yay another starter is dieing..
Old Dec 2, 2011 | 07:41 PM
chris015's Avatar
Default Yay another starter is dieing..
got in the blaze last week,turned key...nothing but lights...tried 4 times then it finally kicked over. did it again today. I installed a used reman starter from a pull it yard this past summer...Man i dont wanna do this again...they are a b^#@h
Old Dec 2, 2011 | 10:57 PM
xgiovannix12's Avatar
yep im dropping mine sunday =(
I bought a world wide with a lifetime warranty
Old Dec 3, 2011 | 08:38 AM
pettyfog's Avatar
Dont be a dumbass like me, Chris... Go buy a new NAPA medium - top line solenoid. Actually any brand but a Wells-Airtex
I spent an hour on my bird starter {it's pretty easy to get at} the other day trying to fix what wasnt broke. All because I didnt stop to think. It was the freakin solenoid not worn brushes as the last time I tore apart a starter
Symptom: Turn key to start, nothing. no sounds. Lights dont dim. Whack starter. Engine starts as usual.
Cause: Solenoid plunger hung up. Other than a bad connection to Ign sw, that's all it can be.
Here's some other symptoms and causes..
Symptom: Turn key to start, hear 'thunk' but no crank. Lights dont dim. Whack starter. Engine starts as usual.
Cause: Solenoid plunger working. Bad high power connection to battery, contacts in solenoid bad, worn brushes. rap on starter and it works.. usually bad contact in sol or brushed
Symptom: Turn key to start, hear 'thunk' but no crank. Lights dim. Whack starter. Engine sometimes starts
Cause: starter armature rubbing field plates, usually worn bearings
chris015
May 16, 2011 12:33 AM
Zasder
Apr 1, 2008 07:56 PM
Thor_449
Mar 31, 2008 05:48 PM
rustyd
Sep 17, 2007 09:36 PM
rustyd
Sep 17, 2007 09:28 PM
