3rd Brake Light(SOLVED)
Old Dec 22, 2008 | 05:07 PM
W2JGA's Avatar
W2JGA is an unknown quantity at this point
Default 3rd Brake Light(SOLVED)
Just noticed tonight, my 3rd brake light does not light. So, I took it off, brought it inside, took it apart, noticed no corrosion or other possible causes of it not working. So I connected it to my power supply and just about blinded myself. Damn those LED's are bright outside of the plastic housing.
So, my question is, from the wiring connector on the roof of the Blazer, are there any modules I need to know about between that connector and the brake pedal switch. Or am I worrying too much about BCM's and should I just rip the brake pedal switch out and test that?
Or, is it something hopefully simple like in one of the tail light assemblies I should be looking?
Old Dec 22, 2008 | 10:31 PM
Default RE: 3rd Brake Light
CHMSL Relay in the underhood fuse block.
Old Dec 23, 2008 | 03:00 AM
W2JGA's Avatar
Thank you for the schematics Kyle. I'll get crackin at this later today after work.
Old Dec 23, 2008 | 03:00 PM
W2JGA's Avatar
Ok, so far I swapped the relay with another identical relay in thefuse center in the engine bay. Still the same results. I disconnected at the 3rd brake light, connected my VOM and Ididn't get any readings. Right now, it's friggin cold outside fiddlin with wires and fuses.
Old Dec 23, 2008 | 03:35 PM
W2JGA's Avatar
Default RE: 3rd Brake Light(SOLVED)
Okay. This is a weird one. While sifting the S10 forum, about 3 or 4 members had the same issue. 1 guy actually found the problem. In the engine fuse bay, there are 2 fuse slots(TRCHMSL and VECHMSL). Both of these slots were EMPTY. I replaced the empty VECHMSL slot with a 10AMP fuse and it works fine now. Now they are all scratching their heads wondering why both of these slots are empty.
Old Dec 23, 2008 | 04:15 PM
Well, if you look at the schematic, both of those fuses are shown (under the relay schematic)... TRCHMSL is for the trailer wiring and VECHMSL is for the vehicle center high mounted stop lamp. I did not have a lot of time last night to type up a reply and get the schematic so I chose to get the schematic up for you.
dano440
May 11, 2012 06:57 PM
sy24
Mar 29, 2011 08:16 AM
steveshane67
Jan 28, 2010 05:06 PM
drperry
Aug 16, 2009 05:24 PM
magnum434
Sep 30, 2006 02:03 PM
